| | | Forums66 Topics128,162 Posts1,056,944 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67109 10/12/2006 12:58 PM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | I just bought a set of SS headers for my 261 from Hotrods of Norco.
Ha!
They welded them from the engine side and let a 3 milimeter welding seam or ridge standing there where the gasket goes - same on the exhaust flanges). (1 hour of grinding and hope they don`t fall appart)
Some clown managed it to weld the "NORCO" Logo plate upside down on the headers.
Where the tubes meet, the hole in the large one is way smaller then the tube diameter of the small one, wich will cause an big edge standing there, awfull turbulence and restriction - almost no chance to grind it down because it is to fare in the tube to reach.
Flanges are bent up to a view milimeters.
Worst of all - it does not clear the column shifter linkage on my 41 sedan.
Good to know that my new boat anchor is SS so it will never rust away.
I wrote them an mail - no reaction since then - Germany is far away.
Aaaargh! :mad: Frank | | |
#67110 10/12/2006 2:38 PM | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 |
#67112 10/12/2006 6:46 PM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | "...added welded O-rings around each port to eliminate leaks." Yeah, right That´s what they call that build in leak. Frank | | |
#67113 10/12/2006 11:03 PM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | The little bit of grinding I had to do on my Patricks re-pops doesn't seem to be a big deal anymore. Thanks Frank. This site is a great way to keep these guys accountable. I was considering those headers. Not anymore. | | |
