6 members (Peggy M, cmayna, baldeagle, JW51, fonz8261, obs2kl), 56 guests, and 5 robots.
Topics128,021
Posts1,055,346
Members48,420
#670713 08/16/2010 6:31 AM
U
U Offline
As i am putting my 1957 Chevy truck back together after paiting, I am starting to notice the paint is chipping in some areas. Tonight I was tighting one of the fender bolts...and not even that tight,,,just trying to start the nut....and I see it chipped . I am starting to see this through the truck..What causes the chipping? Prep work? Poor paint job? How do I prove if it is soemthing to worry about?
Thank you!
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
UnklRod #670726 08/16/2010 12:46 PM
I would vote for all of the above. I am not a bodyman though, but have messed around with enough old stuff. The proof is in the detail. Was it billed as "new paint"? Are you going for recourse from the seller? Might be time to get the ambulance chasers involved.
1963 Chevy C-10 Fleetside
1970 C-30 Dump Truck
2025 Silverado High Country 2500 Diesel
2012 Indian Chief Vintage serial #002 motorcycle
1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout
U
U Offline
Hi 63.
I will have to see if I can find someone that is an "expert" I guess to test the paint (or whatever they do) to see what is going on. I just think it is strange the paint is chipping so easily.
Jon
More pix
UnklRod #670756 08/16/2010 3:26 PM
need to talk to some painters Jon, looks to me like poor bond between paint and primer - might talk to the ones who did the job, but get some 2nd opinions - prolly not much to be done about it ohwell
UnklRod #670758 08/16/2010 3:35 PM
Is this that $35k paint job? I hope the lawyers are better than the painter in your neighborhood.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Definitely looks like a poor bond between the paint and primer to me. A little touchup is unavoidable but chunks falling off like that is definitely not good.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #670799 08/16/2010 6:56 PM
U
U Offline
Once (if ever) I get it on the road I can take it to a shop to have it checked out.
Thank you
More pix
UnklRod #670832 08/16/2010 9:27 PM
What brand and line of primer and paint was used? just currious.
[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
davidn #670860 08/17/2010 12:10 AM
U
U Offline
PPG
More pix
UnklRod #670980 08/17/2010 1:39 PM
One thing You can do to keep from more chipping is only turn the nut side of the bolts that have a washer under them that way the sharp edges of the bolt head or screw head is not pulling on the paint surface also if you can get some small machine washers and use them under the bolt head or screw head you'll barely see them and it will help not chip more paint,Im not saying theres not a problem with you're paint but it will help from more damage to it.
Pete
Pete52 #670987 08/17/2010 2:12 PM
U
U Offline
Hi Pete,
Thank you for the info...Yeah that is a very good idea on not moving the bolt side.
Now, is there a way to fix that chip and make it look like it never was there?
Jon
More pix
UnklRod #671044 08/17/2010 6:53 PM
I did chip or scratch in a few spots because I painted than put the truck together but I brought her back to the painter and had him do it. It took him 1 day to go over the truck and fix a couple of scratchs that I did.
Pete
UnklRod #671122 08/18/2010 12:26 AM
Ex Hall Monitor
Ex Hall Monitor
How old is the paint? Paint might be "dry" in a few days but can take months to fully cure. Even fully cured paint is susceptible to that kind of damage from a screw fastener if it's over tightened. You ever notice modern vehicles rarely use screw fasteners on a painted surface any more.
