| | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 26 | I've searched a little, but haven't really found what I'm looking for. I picked up a '50 3800 that has been converted to 12v with an alternator. My question is what battery specs should I be looking for if any, such as CCAs. Is there a battery that fits best in the OEM compartment under the passenger area? Thanks for the help in advance.
Todd
1950 3800 dually
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | measure the space and compare to what's available in your area, get the highest rated battery you can afford, CCA is probably the best spec to go by Bill | | |
