Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (dt235sd), 203 guests, and 3 robots.
Topics128,299
Posts1,058,705
Members48,493
#671013 08/17/2010 4:36 PM
I've searched a little, but haven't really found what I'm looking for. I picked up a '50 3800 that has been converted to 12v with an alternator. My question is what battery specs should I be looking for if any, such as CCAs. Is there a battery that fits best in the OEM compartment under the passenger area? Thanks for the help in advance.
Todd
1950 3800 dually
Cannon #671030 08/17/2010 5:35 PM
measure the space and compare to what's available in your area, get the highest rated battery you can afford, CCA is probably the best spec to go by
