0 members (),
133
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | I am in th process of redoing a 1951 ad truck. I would like to know what width rear end I need to get the widest tires I can on it. I have a ford 9" that is @56 inches wide, however I am afraid that might be to narrow. Any help would be appreciated. Does anyone know the stock width, I was thinking they were around 62 inches. Thanks for the help
Tony Jacques
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | The width of your rims/tires is more about how much room there is from the leaf springs to the fender. Look on line for custom wheel dealers, most have a drawing of how to measure for your wheel. So using your 9" Ford axle as an example, center it in the wheel opening and measure backspace and front space and if you decide on the Ford you can get your wheels made to your measurements. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | If I remember correctly you have 62 inches to the center of the wheel-well. You didn't say if it was a 1/2 or a 3/4 ton. The 3600 has a frame that is 11 inches more narrow than the 1/2 ton. The 3600 would allow for some pretty big wheels if you want to tub your bed.
~Jim
| | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | All measuring aside a 70's Cmaro rear end fit's fine I can send you a few pic's if you want. Good luck with it,
layback
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Mine is a 10 bolt 1980 Camaro. It fit perfectly and a Firebird disc brakes will bolt right on.
~Jim
