2 members (DennisM, 1 invisible),
80
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | As i am putting my 1957 Chevy truck back together after paiting, I am starting to notice the paint is chipping in some areas. Tonight I was tighting one of the fender bolts...and not even that tight,,,just trying to start the nut....and I see it chipped . I am starting to see this through the truck..What causes the chipping? Prep work? Poor paint job? How do I prove if it is soemthing to worry about? Thank you! 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | I would vote for all of the above. I am not a bodyman though, but have messed around with enough old stuff. The proof is in the detail. Was it billed as "new paint"? Are you going for recourse from the seller? Might be time to get the ambulance chasers involved. 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi 63. I will have to see if I can find someone that is an "expert" I guess to test the paint (or whatever they do) to see what is going on. I just think it is strange the paint is chipping so easily.
Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | need to talk to some painters Jon, looks to me like poor bond between paint and primer - might talk to the ones who did the job, but get some 2nd opinions - prolly not much to be done about it  Bill | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Is this that $35k paint job? I hope the lawyers are better than the painter in your neighborhood. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Definitely looks like a poor bond between the paint and primer to me. A little touchup is unavoidable but chunks falling off like that is definitely not good.
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Once (if ever) I get it on the road I can take it to a shop to have it checked out. Thank you 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 | What brand and line of primer and paint was used? just currious. In the Gallery[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | One thing You can do to keep from more chipping is only turn the nut side of the bolts that have a washer under them that way the sharp edges of the bolt head or screw head is not pulling on the paint surface also if you can get some small machine washers and use them under the bolt head or screw head you'll barely see them and it will help not chip more paint,Im not saying theres not a problem with you're paint but it will help from more damage to it.
Pete | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi Pete, Thank you for the info...Yeah that is a very good idea on not moving the bolt side. Now, is there a way to fix that chip and make it look like it never was there?
Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I did chip or scratch in a few spots because I painted than put the truck together but I brought her back to the painter and had him do it. It took him 1 day to go over the truck and fix a couple of scratchs that I did.
Pete | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | How old is the paint? Paint might be "dry" in a few days but can take months to fully cure. Even fully cured paint is susceptible to that kind of damage from a screw fastener if it's over tightened. You ever notice modern vehicles rarely use screw fasteners on a painted surface any more.
