| | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67069 10/11/2006 1:53 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Are the distributors different between the 216 and the 235? Are they different than the 261?
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
#67070 10/11/2006 3:14 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The 1954 and later truck 235 and 261 distributors are interchangeable.
The 1954 (and '53 Powerglide ??) automobile distributors can work on 54-62 trucks; however, the mechanical advance springs/weights might be different, and the geometry of the vacuum advance units are different.
I think I remember correctly that the pre-54 truck 216/235 distributors are different from the 54 and later distributors (but, this might just be the cap and rotor). Maybe someone who knows will clarify this. | | |
#67072 10/11/2006 9:10 PM | Joined: Apr 2004 Posts: 42 Apprentice | | Apprentice Joined: Apr 2004 Posts: 42 | Napa list the same distributors for the 216 & 235 thru the last one in 1962. The cap & rotor is taller on the 235 but if you change both they work ok. Thanks, Kelly 53 3100 http://www.cravy.com/53-3100/LadyAfterRats.jpg | | |
