2 members (Shaffer's1950, 1 invisible), 117 guests, and 2 robots.
Topics128,094
Posts1,056,464
Members48,443
Hi Bolters-
I need to change the leaky valve cover gasket on my '46 216 engine. The gasket that is on it is probably for a newer 235 since I can see the bulges where the bolt holes would be around the mating surfaces.(this is also the area that leaks the most) My question is what is the best way to install a new gasket? What material should it be? How tight do I tighten the two studs that protrude through the top of the cover? Where can I order a good one online?
Any and all advice will be appreciated.
Rich
46possum
Ex Hall Monitor
Ex Hall Monitor
I ordered mine through the local Bumper To Bumper parts store. Make sure the mating surfaces are clean and smooth by scraping off any old gasket material & wiping off any oil or debris. I simply laid the gasket on the head & carefully installed the valve cover on top of it. Make sure it's positioned correctly before you snug the valve cover nuts. The passenger side lip on the valve cover will keep that side from "pooching" out so your main worry will be the driver's side. Don't overtighten the nuts. Snug is good, smashed flat isn't.
I just got mine through the local NAPA store. It's cork and cost about $12. Just wipe down the surfaces good, carefully position, and snug down. You should be good to go.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
I’ve always used a little #2 Permatex on the cover side and a light coat of grease on the head side. That way the gasket always comes off with the cover and does not stick half to each and tare next time you remove the cover.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
I had leaaky gasket till I tightened up while warm/hot.
