7 members (Hotrod Lincoln, klhansen, Steelonsteel, Ribside, asilverblazer, greenie-reddy, 1 invisible),
63
Mod | | | Forums66 Topics128,261 Posts1,058,326 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 22 New Guy | | New Guy Joined: Aug 2004 Posts: 22 | What 6 lug wheels will fit my 50 chevy3100? Chevy colorado ? (power disc brakes on the front with spacers) Thanks | | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | There are a bunch that have the same 6x5.5 bolt pattern. However you need to check the centre bore on the wheel. Colorado wheels are smaller I think. | | | | | Joined: Aug 2004 Posts: 22 New Guy | | New Guy Joined: Aug 2004 Posts: 22 | What are some? will A LATE MODEL SILVERADO FIT?---- tHANKS | | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | Use ebay as a search tool like I did. Look for 6x5.5 wheels. There's lots on there. Some have good descriptions which include the bore size. | | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | The steel "Rally" wheels from a Chevy K5/Blazer will fit. They're 6 lug, 15" x 8" wide. Backspace is 3.5" so they clear the stock steering arms OK. I have these wheels fitted to my '50 truck, the wheel rims clear the 12" disc brakes I have fitted without a spacer, and although they are wider than the stock rim, they still clear the wheel arches.
Stuart. | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | OK, this is what I've heard....some Chevy trucks up to 1970 used this bolt pattern, then up to '87 4X4 had the right bolt pattern and back spaceing. 1988-2011 Silverados all use the same bolt pattern. I am currently running 17" after-market wheels with 265/70/17s that came off a 2006 Silverado. My brother tells me the Chevy Colorado wheels are a 6 on 5, as opposed to the 6 on 5.5 you need. | | | | | Joined: Jul 2010 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 36 | My truck is a '49 3100 with stock brakes & suspension. I have some aftermarket 15" alum. rims that were on a '89 Toyota 4x4. These were very common in late 80's/early 90's. It gives about 3/4" clearance on tie rods with no rubbing issues. Looks really good, too. 225/75 front & 31/10.5 on rear. These wheels are 6bolt with 12 holes perimeter design. I did have to upgrade the studs (stock 7/16) to longer 1/2" with same size shank. Stock Toyota steels rub the tie rods. | | |
