| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66939 10/08/2006 6:49 AM | Joined: Apr 2006 Posts: 46 New Guy | | New Guy Joined: Apr 2006 Posts: 46 | lOOKING AT MY 1953 GMC 228 FROM THE PASSENGER SIDE, WHAT IS THE FIRING ORDER (GOING FROM LEFT TO RIGHT)? I JUST WANT TO DOUBLE-CHECK. THANKS
1953 GMC half-ton
#66940 10/08/2006 7:06 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | GMC53,
The firing order on your engine is 153624. I'm not sure what you mean left to right. This firing order is the sequence of spark plug wire order around the distributor cap in a clockwise rotation.
Stuart | | |
#66941 10/08/2006 7:18 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | The cylinder numbers would be 6 5 4 3 2 1 left to right from the passenger side, but that is not the firing order. Number one cylinder is always at the front of the engine on American inlines, with the rest following in numerical order. | | |
