0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#66939 10/08/2006 6:49 AM
lOOKING AT MY 1953 GMC 228 FROM THE PASSENGER SIDE, WHAT IS THE FIRING ORDER (GOING FROM LEFT TO RIGHT)? I JUST WANT TO DOUBLE-CHECK.
THANKS
1953 GMC half-ton
#66940 10/08/2006 7:06 AM
GMC53,
The firing order on your engine is 153624. I'm not sure what you mean left to right. This firing order is the sequence of spark plug wire order around the distributor cap in a clockwise rotation.
Stuart
#66941 10/08/2006 7:18 AM
The cylinder numbers would be 6 5 4 3 2 1 left to right from the passenger side, but that is not the firing order. Number one cylinder is always at the front of the engine on American inlines, with the rest following in numerical order.
