3 members (Gdads51, UtahYork, 1 invisible),
109
Mod | | | Forums66 Topics128,191 Posts1,057,364 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 17 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 17 | I am trying to remove my seat springs from the frames and want to ask a few questions so I do not break anything. I am trying to slide the back springs up off the hook and they will not budge. Do I need to pull harder or is there a better way? The bottom springs just lift out, correct?
I also have a question on the jumpseat removal. I have all of the bolts out, except the front toward the driver. I was not able to locate it going through floorboard. Do I need to keep looking or do I have to remove it from inside the truck only?
Thanks for any advice. | | | | | Joined: Nov 2001 Posts: 1,522 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,522 | Theres 2 or 3 small screws that hold the seat cushion to the frame. Along the bottom edge. | | |
