4 members (UtahYork, Shaffer's1950, 2 invisible), 78 guests, and 1 robot.
Topics128,196
Posts1,057,391
Members48,469
I am trying to remove my seat springs from the frames and want to ask a few questions so I do not break anything. I am trying to slide the back springs up off the hook and they will not budge. Do I need to pull harder or is there a better way? The bottom springs just lift out, correct?
I also have a question on the jumpseat removal. I have all of the bolts out, except the front toward the driver. I was not able to locate it going through floorboard. Do I need to keep looking or do I have to remove it from inside the truck only?
Thanks for any advice.
Theres 2 or 3 small screws that hold the seat cushion to the frame. Along the bottom edge.
