4 members (Otto Skorzeny, klhansen, Hotrod Lincoln, Peggy M), 108 guests, and 1 robot.
Topics128,050
Posts1,055,759
#66866 10/05/2006 11:26 PM
Junior Member
Junior Member
Hello, I recently picked up a 454 to replace the 292 in my half ton pickup. I am wondering if anyone sells mounts for this swap, preferably bolt in. Not sure if they would be the same as 67-72 or not. Any help would be appreciated, Thanks.
#66867 10/05/2006 11:58 PM
I haven't done it, but have read that 73-87 mounts will work-but it is still tight near the firewall-no tall valve covers w/o hammering firewall. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#66868 10/06/2006 1:32 AM
May also have fun with exhaust clearing the frame on each side.
#66869 10/06/2006 3:57 AM
I was contemplating the same thing, but have heard that same thing as the other replies. Banging the firewall and header problems. If you do get it in there let us know how it goes for you.
#66870 10/07/2006 2:13 AM
Here\'s my 454 sitting in my K20 frame. Before the ressurection (I'm going way beyond restoration), it had headers on it and they had ample clearance. I went back to manifolds to get away from header maintenance. I have since put the cab on the frame and the fit is tight. When it comes back off for sandblasting, it will get some notching done so I can get the valve cover off someday without having to pull the engine. The mounts are homemade so I can't help you there. It looks like it has the same mounts that came with the engine (77 C20) and welded in brackets to bolt them down to. Good luck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#66871 10/08/2006 1:46 AM
My 66 GMC had a plethora of engines in it over the years... from the venerable original 6 banger, to an LS-6 454, back to a 6, then various SBC's...
Another quality post.
Real Trucks Rattle
