3 members (KEVINSKI, dt235sd, Bill Hanlon), 109 guests, and 2 robots.
Topics128,049
Posts1,055,675
Hello: Can anyone pass on pic's or info on the proper install for the left and right opening windshield brackets for a 1940-46 truck. I have small brass based catch's (for lack of a better word) that mount half way up the left and right inside of my opening windshield (secured from the outside with 2 #8 screws) but I am not sure what they anchor to on the "A" pillars of the truck. Thanks in advance for any help you can provide...
Hi Axle,
My '40 has no such " catches ". Only thing holding windshield is the ( 2) top hinges, and the centre crank at the bottom. I wonder if someone has added these on to keep the windshield tight when closed ?. I have seen some '46's with a cam type lock on the inside face of the A pillar to " suck down " the windshield tightly when closed. Can you post a pic somewhere ?
1940 Chevy KC 1/2-Ton
Originally Posted by britcon
Hi Axle,
My "46" but with a '41 cab has nothing other than the 2 top hinges and the windshield regulator (that I added, it didn't have one at all when I bought it). It leaks air like crazy but I just figure that comes along with the charm of having an open-able windshield. I am not a fan of replacing with a one piece/non opening modern windshield.
Hi: Thanks for the replies....I have included a link to a web album so you can see parts of the catches. It is the anchors that I am having a hard time finding info on. It has been so long since I took these apart and a couple of moves too( so far these and inside door handles are the only thing coming up missing) I think the anchors for the catches have a bit of a triangular shape if thats any help. I have searched quite extensively on the net but no luck.
http://picasaweb.google.com/wilgoo50/1940ChevyWindshieldCatches#
ps don't mind the windshield plastered with bugs, it's a driver and we're having a blast!!!
Looking @ pic's, I would say someone added these along the way - maybe for security, or to pull corner of windshield tighter. They kinda look like old residential window latches ?
as Bruce sez, definitely an owner addition to fix the very common outside corner leaks, no such thing from GM on any opening windshield, if you want to keep them you'll hafta rig your own catch piece
Moderated by  ndkid275, Phak1
