3 members (GMCJammer51, 1955 1 Series, Jay R), 89 guests, and 1 robot.
Topics128,186
Posts1,057,324
Members48,469
I have an 1954 ambulance 235 full pre3sure motor and oil pan is severely dented ,but I have an 1950 parts truck 216 motor which has nice pan still attached.
Can I use that oild pan?
thankyou in advance
The pan bolt pattern is the same from 1940-1954 on 216s and 235s.
I have used a few 216 pans on 1953-54 full pressure 235s but you need to cut the dipper troughs out.
My Blog
Thanks for the correction/clarification, Dave
Hi I want to says to all of you guy for all of you help.
I am going to pull that pan of of my 50 216 motor and try it.
If I have to modify it. It will be better then severly smashed 235 pan.
thanks again
Aren't the ends of the pans different where it is round to fit up to the main caps? Maybe the later pans are improved for a better fit...
Good luck
Professional Novice
