| | | Forums66 Topics128,184 Posts1,057,267 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 20 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 20 | I have an 1954 ambulance 235 full pre3sure motor and oil pan is severely dented ,but I have an 1950 parts truck 216 motor which has nice pan still attached. Can I use that oild pan? thankyou in advance | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The pan bolt pattern is the same from 1940-1954 on 216s and 235s. I have used a few 216 pans on 1953-54 full pressure 235s but you need to cut the dipper troughs out.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thanks for the correction/clarification, Dave
| | | | | Joined: Jun 2007 Posts: 20 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 20 | Hi I want to says to all of you guy for all of you help. I am going to pull that pan of of my 50 216 motor and try it. If I have to modify it. It will be better then severly smashed 235 pan. thanks again | | | | | Joined: Nov 2000 Posts: 1,974 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,974 | Aren't the ends of the pans different where it is round to fit up to the main caps? Maybe the later pans are improved for a better fit... Good luck
Professional Novice
