4 members (rfs56trk, Gdads51, crenwelge, mick53), 79 guests, and 4 robots.
Topics128,264
Posts1,058,357
Members48,485
#668445 08/07/2010 7:51 AM
U
U Offline
What kind of lubricant is used on a stock Delco generator for a 235?
I noticed there are 2 filler holes on mine front and back. But was not sure if I use motor oil. Looking at the assembly manual SEC 14 sheet 9.00 looks like 10W engine oil plus "extreme pressure compound." What is extreme pressure compound?
Thank you!
Jon
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
20 wt engine oil - I use 30 wt oil but I doubt if this makes much difference?
U
U Offline
Hey Tim,
Thank you..I need to get an oil can.
Jon
More pix
3in1 and a few drops in each cup at each oil change.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
....used the 3n1 oil many times...little at each oil change like Bruce suggest. I suspect any mentioned will do OK as long as its done on a regular basic.
I use 3in1 also, and in all the electric motors at the mill, does the job
Back when we actually serviced cars at a "service station" (1960's) we kept a squirt can of 30 weight oil for the oil cups on generators. All part of an oil change/lube job. We also oiled hood hinges, lubed door latches with a wax/grease mixture, and packed spring leaves if the owner requested it. 50 cents extra on a $2.00 lube job for the spring leaf grease!
U
U Offline
Jerry,
Its a job just to find a window squeegee at a service station..much less fresh water!
More pix
True "Service Stations" are few and far between these days. There are two here locally in a city of 100,000+.
Bruce
