4 members (TooMany2count, frogfarmer, moparguy, 1 invisible), 55 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
#667333 08/03/2010 2:01 PM
I have aluminum rocker covers that won't stay polished. In order to keep them up I have to remove them and get out the buffing wheel. They look good for about 3 weeks. I have tried waxing them to no avail. I really dont want to clear coat them. Ideas??
gazim #667335 08/03/2010 2:19 PM
shrink wrap? wink
unless you totally seal aluminum so oxygen can't get at it, it will oxidize, it's just the nature of the beast ohwell
squeeze #667452 08/03/2010 11:45 PM
I've seen my brother paint his new aluminum wheels with clear enron and from then on all he does is wash them. Wheels get a lot more abuse than valve covers.
58 gmc 100 with 350 sbc
LarryW #667580 08/04/2010 1:24 PM
Lerry, what is enron and where can I buy it?
gazim #667602 08/04/2010 3:22 PM
ah zim, I think Enron useta be available .... on Wall Street - but the sound-alike, Imron, is Duponts bulletproof enamel clear coat ohwell
squeeze #667618 08/04/2010 4:32 PM
I have recently used a 2K clear you mix in a can and have gotten fantastic results and would highly recommend it for results and ease of use. Great for smaller jobs with a nozzle pattern better than many guns are capable of and with very good durability.
http://www.eastwood.com/spray-max-rapid-cut-in-spot-clearcoat-aerosol.html
You Tube
Curt B. #667711 08/04/2010 10:28 PM
Thank you I had heard of Emron with mixed thoughts BUt If I had only thought. I believe I had heard of Imron also..thanks.
gazim #668034 08/05/2010 10:13 PM
If you have a shop that does it nearby you might also consider having them anodized.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #668308 08/06/2010 8:14 PM
will check that out.
