7 members (Rusty Heaps, DaveV, TexasA&M48Truck, Peggy M, TUTS 59, 78buckshot, Otto Skorzeny),
187
7
Mod | | | Forums66 Topics128,078 Posts1,056,039 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I have aluminum rocker covers that won't stay polished. In order to keep them up I have to remove them and get out the buffing wheel. They look good for about 3 weeks. I have tried waxing them to no avail. I really dont want to clear coat them. Ideas??
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | shrink wrap? unless you totally seal aluminum so oxygen can't get at it, it will oxidize, it's just the nature of the beast  Bill | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | I've seen my brother paint his new aluminum wheels with clear enron and from then on all he does is wash them. Wheels get a lot more abuse than valve covers.
58 gmc 100 with 350 sbc
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Lerry, what is enron and where can I buy it? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | ah zim, I think Enron useta be available .... on Wall Street - but the sound-alike, Imron, is Duponts bulletproof enamel clear coat  Bill | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I have recently used a 2K clear you mix in a can and have gotten fantastic results and would highly recommend it for results and ease of use. Great for smaller jobs with a nozzle pattern better than many guns are capable of and with very good durability. http://www.eastwood.com/spray-max-rapid-cut-in-spot-clearcoat-aerosol.html
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Thank you I had heard of Emron with mixed thoughts BUt If I had only thought. I believe I had heard of Imron also..thanks. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | If you have a shop that does it nearby you might also consider having them anodized. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | | | |
