9 members (Hotrod Lincoln, Otto Skorzeny, CuzzFuzz, Shaffer's1950, SlimSix, TrknGMC, homer52, 2 invisible), 95 guests, and 3 robots.
Topics128,139
Posts1,056,451
Members48,441
#667937 08/05/2010 3:31 PM
I finally have my '55 235 runninng in my '50 Chevy AD and of course now have to deal with the too long water pump shaft. Because there are options,I'm not sure what may be the best solution. New pump,rework existing pump and/or buy the relocation plate? What has been your experience as to what worked for you?
Drew
The relocation plate has worked best for me.
Thanks, Tim. Does the block have to be drilled and tapped in two places as stated in the EBay ad for these plates?
Drew
DrewP
I bought short water pump from Patricks and worked for me, just my experience.
Rgds.,
Ganesh
When you buy the plate, ask for instructions to be sent with the plate.
Here is a good photolog og an installation from Fla54Chevy3100:
http://good-times.webshots.com/photo/2803060960090459121lrHQVU
The plate allows you to use an older water pump (shorter shaft) in the correct cooling location for a pre-55 truck.
Thanks again! I think that's the way I will go. I was worried about the drilling, but instructions make it sraight forward.
Drew
