| | | Forums66 Topics128,078 Posts1,056,051 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 9 New Guy | | New Guy Joined: Dec 2008 Posts: 9 | I don't know if this would be the right place or not but here goes. I need to see if any of you have any pictures of a '65 283 motor with power steering. I have all the parts for conversion (pump, steering box, conversion plate, etc.) but i can't seem to figure out a way to mount my pump. I need some ideas original or aftermarket. Anything would be a big help thanks. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you maybe don't have the heads with the necessary accessory mount holes in the front?
Bill | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | heads have nothing to do with the p/s pump mounting. do you have the p/s pump mounting bracket. it goes to the 2 holes to the d/s of the crank pulley and back to the frt eng mount. pm me you email and I can send you pics later as I have a bracket somewhere. just have to dig it out ron I take it that you are using the short w/pump
| | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | Along those same lines I have a 66 gmc with a 6 cylinder, where can I come up with the stock brackets for a conversion to power steering, and the stock bracket for the pump on the 6 engine?
66 GMC SWB 65 Chevy LWB 65 GMC SWB
918-446-2245
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | they do come up on ebay for the v6 once in a while,not as common as sbc. also the 60-66 gmc board. make sure that you get all the corresponding pulleys. you can use a later style steering box and eliminate the hydr cyl ron
| | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | Thanks, Padresag I will take a look. I found links to power steering conversions, a nice looking kit for 585.00 but the supplier must have gone out of business......just my luck.
918-446-2245
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | HERE'S a post from the 67-72chevytrucks website, it should help you out...joe I believe that he is talking a gmc305 V6 and you just have to hunt for the pieces ron referring to Keith's question, not the orig. funny that the orig hasn't responded as i would have sent him some pics
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Mike....as padresag said, it is a steel bracket assembly that mounts low on the drivers side - mine has just 2 bolts to block as I have custom motor mounts on my 327. You would use a Saginaw style PS pump with belt drive to crank & fan pulley. I would think these might be available at a wrecking yard like All American Classics in Vancouver, Wa. www.allamericanclassics.com | | |
