| | | Forums66 Topics128,022 Posts1,055,381 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66780 10/04/2006 2:51 AM | Joined: Feb 2006 Posts: 45 Junior Member | | Junior Member Joined: Feb 2006 Posts: 45 | hi i have a 1951 chevy 3800 1 ton single wheel is that all correct because i have seen some one ton trucks and there dual wheel mine is single.. 235 4 spd with teh 17inch split rims is this correct? | | |
#66781 10/04/2006 3:12 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Yes, that is corrcet. There were single wheel 1 Tons and that is what I have. Mine came with the 17" split rims too. What GVW do you have on your tag? | | |
#66782 10/04/2006 3:35 AM | Joined: Feb 2006 Posts: 45 Junior Member | | Junior Member Joined: Feb 2006 Posts: 45 | i think itt 8,800 lbs also my truck used to be a tow truck but im not sure if it was its hole life i wish i could find out where my truck started do u kno where i can ? if thats possible -derek | | |
#66783 10/05/2006 2:23 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I know that the GM restoration packs in Canada, tell what factory it came from and the date. | | |
#66784 10/08/2006 3:34 AM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If you have more than 4 running board brackets total or running boards that have been shortened with a torch to the length of the cab than you had a pickup truck when it was new, with a 9 foot bed.
Let's see some pictures? | | |
