5 members (Otto Skorzeny, TooMany2count, Eisenholtz, Shardean, Gdads51), 58 guests, and 3 robots.
Topics128,023
Posts1,055,366
Members48,420
#66780 10/04/2006 2:51 AM
Junior Member
Junior Member
hi i have a 1951 chevy 3800 1 ton single wheel is that all correct because i have seen some one ton trucks and there dual wheel mine is single.. 235 4 spd with teh 17inch split rims is this correct?
#66781 10/04/2006 3:12 AM
Yes, that is corrcet. There were single wheel 1 Tons and that is what I have. Mine came with the 17" split rims too. What GVW do you have on your tag?
1951 1 Ton Completed
#66782 10/04/2006 3:35 AM
Junior Member
Junior Member
i think itt 8,800 lbs
also my truck used to be a tow truck but im not sure if it was its hole life i wish i could find out where my truck started do u kno where i can ? if thats possible
-derek
#66783 10/05/2006 2:23 PM
I know that the GM restoration packs in Canada, tell what factory it came from and the date.
#66784 10/08/2006 3:34 AM
If you have more than 4 running board brackets total or running boards that have been shortened with a torch to the length of the cab than you had a pickup truck when it was new, with a 9 foot bed.
Let's see some pictures?
1952 Chevrolet 3800 pickup
---All pictures---
