5 members (DoubleB, EchoBravoSierra, frogfarmer, TooMany2count, Achipmunk), 55 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
#667503 08/04/2010 3:23 AM
I don't know if this would be the right place or not but here goes. I need to see if any of you have any pictures of a '65 283 motor with power steering. I have all the parts for conversion (pump, steering box, conversion plate, etc.) but i can't seem to figure out a way to mount my pump. I need some ideas original or aftermarket. Anything would be a big help thanks.
1965 Chevy C10 Fleetside
If you think you did it right the very first time, chances are you got it wrong.
www.mfgraphpro.webs.com
you maybe don't have the heads with the necessary accessory mount holes in the front?
heads have nothing to do with the p/s pump mounting.
do you have the p/s pump mounting bracket. it goes to the 2 holes to the d/s of the crank pulley and back to the frt eng mount. pm me you email and I can send you pics later as I have a bracket somewhere. just have to dig it out
ron
I take it that you are using the short w/pump
Along those same lines I have a 66 gmc with a 6 cylinder, where can I come up with the stock brackets for a conversion to power steering, and the stock bracket for the pump on the 6 engine?
66 GMC SWB
65 Chevy LWB
65 GMC SWB
918-446-2245
they do come up on ebay for the v6 once in a while,not as common as sbc.
also the 60-66 gmc board. make sure that you get all the corresponding pulleys. you can use a later style steering box and eliminate the hydr cyl
ron
Thanks, Padresag I will take a look. I found links to power steering conversions, a nice looking kit for 585.00 but the supplier must have gone out of business......just my luck.
66 GMC SWB
65 Chevy LWB
65 GMC SWB
918-446-2245
#668795 08/08/2010 7:07 PM
Originally Posted by TooMany2count
HERE'S a post from the 67-72chevytrucks website, it should help you out...joe
I believe that he is talking a gmc305 V6 and you just have to hunt for the pieces
ron
referring to Keith's question, not the orig. funny that the orig hasn't responded as i would have sent him some pics
Mike....as padresag said, it is a steel bracket assembly that mounts low on the drivers side - mine has just 2 bolts to block as I have custom motor mounts on my 327. You would use a Saginaw style PS pump with belt drive to crank & fan pulley. I would think these might be available at a wrecking yard like All American Classics in Vancouver, Wa. www.allamericanclassics.com
1940 Chevy KC 1/2-Ton
