3 members (hardshell, FishinToms53, lumbersawyer), 45 guests, and 3 robots.
Topics128,030
Posts1,055,428
Members48,422
#667255 08/03/2010 1:59 AM
I have a '59 Apache 6 cyliner. The original tank was removed when i got it and I have replaced the gas tank, sending unit, filler neck, pump, and installed a carb kit.
I noticed the lines smelled like varnish so i used some paint thinner to try and cut it. It seemed to work pretty good and after I replaced the pump Iused the starter to turn the engine over. I got a good stream of gas and noticed it was pretty dark.
Is there anything I can use to clean the varnish out now or maybe some additive to get this thing going?
GeneBrownlow #667283 08/03/2010 3:45 AM
Drain everything completely. If the varnish gets in your engine, it will stick your valves. Something like Marvel Mystery oil will dissolve it as good as anything.
crenwelge #667332 08/03/2010 1:57 PM
GeneBrownlow #667336 08/03/2010 2:31 PM
I haven't seen it in years but Bardahl Upper Cylinder Lube was one of the best for unsticking valves. There may be something new out there that I'm unaware of.
For those my age you may remember Blackie Carbon, Bardahl's mystery man in the raincoat and Fedora.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #667342 08/03/2010 3:11 PM
no! Dave no! the trenchcoat guy was the Bardahl man, Blackie Carbon was onea "the gang" grin
