3 members (Jay R, Hanks custodian, 1 invisible),
122
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 70 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 70 | I just ordered a wiring harness from Classic Parts and I have questions before I proceed. Here is what I got: 283 V8(originally 6 cyl), HEI, alternator. I think I also have the original two position ignition switch for a 6 cyl. Did this old ignition switch necessitate the installation of the under dash push button for the starter a previous owner installed? Should I try to do the same thing with the new harness, or just get a new igniton switch. I was thinking an electric foot switch would be cool, just wire up like the push button?
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you could fake it with the foot stomp, if it activated an electrical switch like the dash push button - it's your call but I'd recommend going with the correct key start V8 ignition switch Bill | | |
