Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (SandraD, baldeagle, farmallb, Peggy M), 51 guests, and 1 robot.
Topics128,005
Posts1,055,261
Members48,418
#666874 08/01/2010 5:53 PM
in this schematic I found in a 1950 popular mechanics viable?
http://img.photobucket.com/albums/1003/45nut/wiring.jpg
Looking specifically at the coil it doesn't really show which post is pos or neg.
45nut #666880 08/01/2010 6:31 PM
The old car manual project has alot of this kind of stuff. Search there.
45nut #666881 08/01/2010 6:38 PM
"viable"? it appears to be an accurate basic representation of a general ignition system, but what's wrong with the one in your shop manual?
+/- will usually be marked on the coil - pos goes to the hot spot, the neg goes to the side peg of the dist
I was looking for a simplified schematic that is easier to read than the ones I had seen, your reply as to the neg to dist is exactly what I needed though, thanks!
45nut #666921 08/01/2010 9:35 PM
3B Offline
Hy 45nut, the terminal which is connected to the distrbutor from the coil, is dependant on the chassis ground. On negative ground vehicles the coils negative terminal connects to the distributor, on positive ground vehicles the positive terminal of the coil connects to the distributor, hope that helps.
