| | | Forums66 Topics128,196 Posts1,057,386 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 22 | 1946 1/2 ton. Is there a trick to removing the door latch connecting link from the latch & from the handle operator?
Each end has a "T" post c/w washer & spring that rides in a slot. The "T" posts are staked in.
Thanks | | | | | Joined: Jun 2008 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 22 | Problem solved. Originally there was a spring & washer installed before the "T" peg was staked in. When the connecting link is installed it is put over the T peg then rotated 90 degrees into position. The washer is on one side of the link & the T is on the other
Over the years, with wear on the connecting link the washers on three of 4 connectors have migrated to the T side of the connecting link. Since I need to make/buy new links anyway I cut a slot in the link to allow temoval. | | |
