| | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 34 | i bought this vehicle locally after it sat in a garage for 15 years.i cleaned the carb and fuel pump and got it running.when it is in park it makes a loud grinding noise,but when i put it in gear it goes away.i thought it could be the starter so i put a shim in but the noise is still there. any suggestions? | | | | | Joined: Feb 2000 Posts: 5,229 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,229 | Check the motor mounts, and front pulleys for any sign of wear or scratches. It could be that once you drop it in gear, the torque is holding the engine over to the side just enough to not hit something. The other option is something is wrong inside the powerglide.
Joe | | |
