7 members (Oswald, FAST55, Ponchogl, 2-Ton, Oldcaliforniakid, Hotrod Lincoln, Donf),
74
Mod | | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 71 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 71 | I would like to fuse the hot wire from the battery to the cab. Does anyone know what would be the right amp fuse to use?
Thanks, Mark P. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A 50 amp will probably do but it also depends on what accessories you have.
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I'm running with a 20 amp Bus fuse. My intention was to switch to 30 amp if needed but it hasn't blown yet. | | | | | Joined: Feb 2004 Posts: 29,755 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,755 | Are you running an alternator or a generator? The fuse link needs to be able to handle the highest battery charging current that's available from the charging system after startup, if you're running a standard wiring harness with the charging current going through the ammeter. I've seen short current surges of 80-100 amps from some alternators after a long cranking session. If you have a separate charging wire from the alternator to the battery, no problem, but the ammeter won't work right. Use a 50 amp fuse link, but be prepared to go bigger if it burns out from high alternator current. Jerry
| | | | | Joined: Jun 2010 Posts: 71 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 71 | It's a 1967 C10 with a 250ci engine. The truck has an alternator, it's plain no power anything just a radio. Someone local said they thought it should have a 35 amp alternator but were not 100% sure. Does this sound right and if it is should I try a 30 amp or use a 50amp? Mechanical work I'm ok at but electrical systems not so much.
Thanks, Mark | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | 50 AMP min. i run 5 relays to:: low beams x1, high beams x1, pusher fan x2, fog lights x1 all my relays have a fuseble link http://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=0732700-R1-034-15A.jpg
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Feb 2004 Posts: 29,755 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,755 | I've never heard of an alternator with less than a 55 amp capacity. Most of the internal-regulated 10SI models are 65 to 100 amp capacity. If you choose to use a fusible link between the dash cluster and the ammeter, it should be able to carry at least most of the alternator's output. If there's a direct wire from the alternator output terminal to the top terminal of the starter, you could use a 40 or 50 amp fuse or fuse link to the ignition switch or other junction point to the inside accessories, and an idiot light instead of an ammeter to monitor charging system performance. Jerry
