1 members (baldeagle), 89 guests, and 4 robots.
Topics128,037
Posts1,055,466
Members48,424
#666045 07/29/2010 4:27 AM
I would like to fuse the hot wire from the battery to the cab. Does anyone know what would be the right amp fuse to use?
Mark P.
A 50 amp will probably do but it also depends on what accessories you have.
I'm running with a 20 amp Bus fuse. My intention was to switch to 30 amp if needed but it hasn't blown yet.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Are you running an alternator or a generator? The fuse link needs to be able to handle the highest battery charging current that's available from the charging system after startup, if you're running a standard wiring harness with the charging current going through the ammeter. I've seen short current surges of 80-100 amps from some alternators after a long cranking session. If you have a separate charging wire from the alternator to the battery, no problem, but the ammeter won't work right. Use a 50 amp fuse link, but be prepared to go bigger if it burns out from high alternator current.
It's a 1967 C10 with a 250ci engine. The truck has an alternator, it's plain no power anything just a radio. Someone local said they thought it should have a 35 amp alternator but were not 100% sure. Does this sound right and if it is should I try a 30 amp or use a 50amp? Mechanical work I'm ok at but electrical systems not so much.
Mark
50 AMP min.
i run 5 relays to:: low beams x1, high beams x1, pusher fan x2, fog lights x1
all my relays have a fuseble link
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=0732700-R1-034-15A.jpg
Jim & Caroline
I've never heard of an alternator with less than a 55 amp capacity. Most of the internal-regulated 10SI models are 65 to 100 amp capacity. If you choose to use a fusible link between the dash cluster and the ammeter, it should be able to carry at least most of the alternator's output. If there's a direct wire from the alternator output terminal to the top terminal of the starter, you could use a 40 or 50 amp fuse or fuse link to the ignition switch or other junction point to the inside accessories, and an idiot light instead of an ammeter to monitor charging system performance.
