| | | Forums66 Topics128,188 Posts1,057,217 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 31 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 31 | I have a 1951 1/2-ton Chevrolet Pickup, and want to put a foot operated E-Brake in the original location. And also the cable set-up, length and routing...of how to do it.
About 31-years ago, I cut the original out, because it was rusted out, in that area of the floor. I installed sheet metal where the original E-Brake was. I have a 350 in it, with a Muncie 4-speed. The rear end is different also.
But this is something that I've always wanted to do. Installing an E-Brake, and not the original stuff either. Could somebody please give me some tech-tips on HOW TO DO this foot set-up, and what all do I need to do this project...cables, rods, and length to both rear wheels?
Any information help would be appreciated. Thanks, JEFF
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | You might want to have a look at the Lokar site for aftermarket E Brake cables, pedals, etc. I installed a pedal style on my '40, and have had issues with cable routing around exhaust and driveline. If I were to do it again, I would opt for hand brake mounted in center of cab. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | britcon hit the nail on the head but in my opinion unless your running buckets it may be a little more of a challenge to put the hand brakes in it.
Here are my plans... I left the original rear end under my 52panel but I changed the torque tube out for a pumpkin from a later 50's model truck. So, I still have the cross rod going through each side of my chassis that the E-cables hook to. On this cross rod, just about in the center, is a tab to hook a cable to . I can run it almost right up the middle (though a support eye, and to a hand brake that I'm putting beside the drivers bucket seat. Just TODAY a friend of mine is junking out a Colt and told me I could have the center brake handle and anything else I wanted. Just comoe take it out... .and the console is already out of it!!
Hope this gives you some hope and ideas. We have to stop!!
I understand your dilema as my drivers side was so rotted away. I have pics and some measurement and a couple models close by to look at but the and brake system like in teh honda, Nissan, Colt ect sure are neat. | | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | Should be a picture of the hand E-Brake fitted in my '50 1/2 ton here E-Brake photo I fitted a lever from an earlier Chevy truck, there's plenty of room for it to work with the bench seat. The lever setup is fitted a bracket that bolts to the side of the Brake master cylinder mounting that's under the floor. The operating rod from the lever lines up almost perfectly with the stock E-Brake cross shaft. | | | | | Joined: Feb 2007 Posts: 31 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 31 | I've seen Lokar products. I'm just trying to figure out how to fabricate it. I have the stock bench seat with a manual transmission, with the shifter in the middle of the floor. Its about centered in the middle of the rectangular removal transmission plate. My truck originally had the 3-speed on the column. Of course that set-up and steering column are gone.
But anyway, thats why I'd like to put a foot operated E-brake set-up in my truck. I never gave it much thought in the past, but now I want an E-brake in my truck. Just putting it in gear is not enough for safety, wheel chalks.
I don't have the stock large rod that goes through frame. I discarded that about 10-years ago when I put a dual Master Cylinder in my truck. Its still drum brakes with two 10-lb residual valves for the front and rear brakes. I didn't like the original single M/S.
Anyway, didn't mean to get so lengthy on this subject. I appreciate all who replied to me on this subject. Any more information that would help...please share. I want to do this E-brake on my truck...finally.
Again, thankyou everyone for the info help!
JEFF
| | | | | Joined: Feb 2007 Posts: 31 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 31 | Anybody else got any information on E-Brake set-up work on my '51 AD? Like how to attached both cables to both real wheels evenly, in the set-up work to be done? I guess what I'm trying to say is...the routing of cables, and especially the turns of cables...some kind of a track for both cables to follow, linkage rods, etc? I like the small version, foot pedal set-up from Lokar. But its the routing hook up from the foot pedal assembly to both rear wheels?
Would be grateful for any information help on this. Thanks Stovebolters!
JEFF
| | | | | Joined: Sep 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 48 | I just used the lokar cables for hooking up the e brake to an 85 camaro rearend in my 53 3100, for the money its the way to go, they also have a couple ebrake setups, everything is pretty well thought out and it is truly a "BOLT IN" ITEM.. WELL WORTH EVERY PENNY... | | |
