4 members (MickeyP, Peggy M, Bwana-Jim, Wayne67vert), 82 guests, and 1 robot.
Topics128,033
Posts1,055,531
Members48,425
#665479 07/27/2010 8:52 AM
Hey all,
My question is: Are cab's interchangeable? The cab on my 63 short/step is rusted out really bad. I got a line on another one but I think it was on a 64 or 65, maybe even a 66. What cab's from these years (60-66) can I swap without any problems. I haven't bought this other cab but I don't want to let it get away either cuz its in great shape. HEEEELLLLPPPPP!!????
lowridin63 #665486 07/27/2010 11:52 AM
60-63 trucks have a different cab. they have a wrap around windshield and differnt doors. Im sure it would mount on your truck but there are probably other things that mount differntly to the cab that you would have to change. Im sure some of the other guys can give you more info. take a look at some of the trucks in the gallary and you will see what im talking about.
61nate #665773 07/28/2010 6:41 AM
Ok thanx. I guess I'll look around for my year cab so I can use most of what I got. If anyone has any other ideas or has swapped cabs before, I could sure use the tips and info. Thanx.
lowridin63 #665992 07/29/2010 1:50 AM
lowridin63, the shop manual for a 1964 truck starts with the 1963 manual. The 64 manual is only a supplement. According to the index for the 64 manual section 2 "Frame" indicates that there is no change between the two.
Also when I mounted my cab back on my 64 I used the dimensions from the factory assembly manual (located about 1/2 way through it) to verify my frame was good to go. I judge that this particular section of the assembly manual is for 1962. These dimensions matched what my 64 frame had.
I believe that all the 64 front end sheet metal (fenders, hood, etc.) will fit on a 63 as well.
So it seems to me that the biggest concern you have is are you ok with the look of a 64 cab on your 63.
That and you will have to always remember what year parts you will need depending on what part of the truck you are working on.
Rusty64 #666048 07/29/2010 4:33 AM
If you were to use a 60 through 62 cab you would need to save the master cylinder and clutch / brake pedal assembly from the other cab unless you want to change to a hydraulic clutch.
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
Joe McNeel #677042 09/11/2010 7:49 AM
Thanx men. I'll try to find a '63 cab. I'm with you guys about keeping it all original. Seems much easier that way.
