| | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 31 Apprentice | | Apprentice Joined: Mar 2010 Posts: 31 | i was wondering what grit of sandpaper you guys used to remove surface rust on your trucks,my cab and bed are completely covered in surface rust.I have been using a DA air sander with 80 grit disk,but it seems to be going really slow and not getting to much off.Whats a good safe grit to get rid of he rust without scratching the metal to much? | | | | | Joined: Aug 2007 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 116 | One of the guys here talked about a paint stripping tool he bought for his grinder. I don't recall the name of it. I bought something at home depot... Fits my 4 1/2" angle grinder.... The surface of the pad is blue... Cost me 10 bucks I think. It makes short work of stripping paint and rust. It doesn't beat up the metal either
Matt
http://www.flickr.com/photos/50657267@N08/sets/
1939 1/2 ton Resto-mod 1937 1 1/2 ton Is in the driveway
| | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | They are called Norton rapid strip discs. The blue variety is available at the big box stores, hardware stores, and some paint stores. There is also a black variety that is their industrial line and I have only found that at welding shops or on-line. For me, the black have lasted longer than the blue but either discs work great! They are available to fit a grinder as mentioned but also come in a wide variety of other shapes and sizes. I have used a wide variety of products for stripping to bare metal. They all have their uses but the Norton rapid strip discs have worked the fastest and lasted longer than anything else I have tried for your described use.
Chuck | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | They are called Norton rapid strip discs. The blue variety is available at the big box stores, hardware stores, and some paint stores. There is also a black variety that is their industrial line and I have only found that at welding shops or on-line. For me, the black have lasted longer than the blue but either discs work great! They are available to fit a grinder as mentioned but also come in a wide variety of other shapes and sizes. I have used a wide variety of products for stripping to bare metal. They all have their uses but the Norton rapid strip discs have worked the fastest and lasted longer than anything else I have tried for your described use.
Chuck I agree they work good. I also use a wire brush on my grinder to get into the hard to reach areas | | |
