8 members (78buckshot, Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible), 38 guests, and 10 robots.
Topics128,012
Posts1,055,312
Members48,419
#665645 07/27/2010 11:24 PM
Apprentice
Apprentice
1 Offline
i was wondering what grit of sandpaper you guys used to remove surface rust on your trucks,my cab and bed are completely covered in surface rust.I have been using a DA air sander with 80 grit disk,but it seems to be going really slow and not getting to much off.Whats a good safe grit to get rid of he rust without scratching the metal to much?
1953mn #665718 07/28/2010 3:33 AM
One of the guys here talked about a paint stripping tool he bought for his grinder. I don't recall the name of it. I bought something at home depot... Fits my 4 1/2" angle grinder.... The surface of the pad is blue... Cost me 10 bucks I think. It makes short work of stripping paint and rust. It doesn't beat up the metal either
Matt
http://www.flickr.com/photos/50657267@N08/sets/
1939 1/2 ton Resto-mod
1937 1 1/2 ton Is in the driveway
fatboy0169 #665888 07/28/2010 7:11 PM
They are called Norton rapid strip discs. The blue variety is available at the big box stores, hardware stores, and some paint stores. There is also a black variety that is their industrial line and I have only found that at welding shops or on-line. For me, the black have lasted longer than the blue but either discs work great! They are available to fit a grinder as mentioned but also come in a wide variety of other shapes and sizes. I have used a wide variety of products for stripping to bare metal. They all have their uses but the Norton rapid strip discs have worked the fastest and lasted longer than anything else I have tried for your described use.
Chuck
Hookalatch #665967 07/29/2010 12:26 AM
Chuck
I agree they work good. I also use a wire brush on my grinder to get into the hard to reach areas
