8 members (HandyAndy, 52Carl, 55shaker, Cosmo, RoadsScholar, Jay R, Ponchogl, 1 invisible), 76 guests, and 0 robots.
Topics128,049
Posts1,055,629
#665640 07/27/2010 11:10 PM
Apprentice
Apprentice
1 Offline
just got my "new" 53 and cant get the good to open,i can feel what feels like 2 latches one under the center of the hood and one to a little right of the center of the hood under the first grill bar,i've tried everything but still cant get the darn thing open.could the latch be stuck the PO had it open yesterday but i just cant figure it out.
1953mn #665644 07/27/2010 11:18 PM
The lever to the right of center should open the hood unless modifications have been done. Try pushing down fairly hard and releasing the hood with one hand while you have the lever pulled with your other. Sometimes this will work if there is a bind on the latching mechanism.
Chuck
Apprentice
Apprentice
1 Offline
Ok thanks,I did what you said,but now there's a new problem after I got it open I shut it,and when I went to open it again the release lever bent and the hood never popped,the more I pushed the lever it just bent more, is there away to get around the release somehow?
Y
Y Offline
Try to straighten the lever, it will bend back to some degree. Again push down on the hood, or have someone else push while you work the release lever. Once you get the hood open it time to learn how to adjust the "striker" bolt. A properly aligned hood and properly adjusted hood latch should be easy to open and close. A little lubrication also helps. The bolt has to center in the latch or it will hang up inside the latch. Keep trying, and make sure the safety catch works!!! Those hard to open hoods always come open at about 50 miles and hour!!!
fortunately 50 mph is top speed as well.
May try pulling that latch friend. Welcome to the bolt.
1952 Chevy 3100
More pictures in Photobucket
Doin better'n some an worse than others. Life's what ya make of it. FAMILY, GOD and COUNTRY. Love it or Leave it.
Apprentice
Apprentice
1 Offline
well Old Dollar you hit the nail on the head, as it turns out i was pushing down to much and not pulling it towards me enough, 10 hour days at work for the last week must be getting to me.Thanks for all the help and warning about the hood opening up at 50mph,its happened to me all ready going to fast down a road that was to bumpy
1953mn #667085 08/02/2010 12:40 PM
If the hood is opening up you may want to try adjusting front end, radiator support, etc...
1952 Chevy 3100
