Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (1955 1 Series, Peggy M, Jon G), 49 guests, and 4 robots.
Topics128,009
Posts1,055,296
Members48,419
#6654 12/12/2004 1:49 AM
Anyone else had trouble with Masterpower power brake/master cylinder units? I installed a power brake setup and began having trouble with the brakes draging. after changing hoses, cables, springs and everything else. I finally found the fault was the mounting of the master cylinder on the booster. The drive rod of the booster is a 1/4" too long. I have to install the reworked unit be I think it's fixed now. Is this typical of Masterpower's work?
if it dosen't need fixed, break it
#6655 12/12/2004 3:46 PM
Its probably typical of everything bought now, no one cares about their job or anything. I get parts all the time that have to be made to fit, didn't have to do this a few years back. Think of trying to make a living when there is a set time you are paid to R&R a part then you spend extra time figgering out it's not adjusted correctly from the factory or doesn't fit, you have to make it fit. Cuts into the paycheck. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
