1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#66538 09/28/2006 12:14 AM
Hey guys' is a 235 bellhousing and flywheel the same as a 216? Thx.
Glenn,
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
#66539 09/28/2006 12:18 AM
3B Offline
Hy GEC52, If it's the same year it's probably the same housing, hope that helps.
#66540 09/28/2006 3:48 AM
1937-62 216, 235, and 261 all have the same bellhousing bolt pattern.
1942-62 216, 235, and 261 use the same flywheel bolt pattern.
My Blog
#66541 09/28/2006 4:24 AM
3B Offline
Hy guys, What Pre'68 Dave said is true about the bolt pattern to bolt to the engine, but there are different mount types and different transmission bolt patterns involved in that long span of years he mentioned, hope that clarifies.
#66542 10/02/2006 12:37 PM
Thx Guys,
That helps. So I can bolt my bellhousing, flywheel and tranny to either a 216 or 235.
Glenn,
1952 Chevy 1/2-Ton
#66543 10/02/2006 3:49 PM
I just did that Glenn. No problem.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#66544 10/02/2006 4:45 PM
Good subject...
So I should have no problems bolting a 216 1947 bellhousing to a 261 1961 ...?
Would a larger 11" 1961 flywheel & clutch still fit...?
If not, which bell housing to look for between a 261 1961 and a 1947 original 3-speed...?
I experienced a surprise 2 years ago when I replaced my flywheel and clutch on my 1952 truck with 235 from 1962.
I wanted to upgrade from my 9-1/4" setup to the larger 11".
However a 1962 11" flywheel did NOT bolt onto the crankshaft.
I had to get a 1955 resurfaced 9-1/4" flywheel like I used to have.
I know my 52 truck and 62 engine was rebuilt with 54/55 parts, before I got it.
So I figured maybe the crankshaft on mine was 55 to match with the original transmission and 9-1/4" clutch.
Pretty mysterious still today.
On the road every day...
1952 Truck - 235
1948 Coupe - 261
#66545 10/24/2006 4:29 PM
Don't know if this is of any help or not, but I put a '55 235 into my 1940 GMC last year. I wrote up some lessons learned here:
http://oldgmctrucks.infopop.cc/eve/forums/a/tpc/f/462107036/m/4471020781
Steve
See my 1940 Canadian GMC:
http://community.webshots.com/user/ndnchf
