5 members (Guitplayer, GRNHydra, Otto Skorzeny, Napco Man, Paul_WNC), 242 guests, and 8 robots.
Topics128,078
Posts1,056,039
Members48,433
#665122 07/25/2010 11:17 PM
Am I the only one who thinks how difficult is to bolt radiator to radiator support. Trying to put bolts through the small gap, how was GM keeping up with the production rate. What is ur trick
Ganesh
Y
Y Offline
Do you have one of those trucks that the PO made an engine swap, and moved the radiator forward/inside the support? The heavy duty radiators, or long water pumps required something had to move and the radiator was it!
I made the 235 motor swap with short water pump but still original radiator setup
Ganesh
Ganesh,
I am looking to make the same swap. Will a radiator from a '53 fit the mounts for a '54?
Carlos
Not clear what the problemis here. The six bolts from the back side of the core support are easilly accesable.
I did run into a '50 GMC in a junk yard once that had the bolts run in from the front and I fought with it for a couple of hours on a cold, snowy December afternoon. I don't remember exactly why they were that way but I do know that it wasn't the stock setup.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
