| | | Forums66 Topics128,051 Posts1,055,768 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Am I the only one who thinks how difficult is to bolt radiator to radiator support. Trying to put bolts through the small gap, how was GM keeping up with the production rate. What is ur trick
Ganesh | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Do you have one of those trucks that the PO made an engine swap, and moved the radiator forward/inside the support? The heavy duty radiators, or long water pumps required something had to move and the radiator was it! | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | I made the 235 motor swap with short water pump but still original radiator setup
Ganesh | | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Ganesh,
I am looking to make the same swap. Will a radiator from a '53 fit the mounts for a '54?
Carlos | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not clear what the problemis here. The six bolts from the back side of the core support are easilly accesable. I did run into a '50 GMC in a junk yard once that had the bolts run in from the front and I fought with it for a couple of hours on a cold, snowy December afternoon. I don't remember exactly why they were that way but I do know that it wasn't the stock setup. Denny Graham Sandwich, IL
Denny G Sandwich, IL
