0 members (), 166 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#664871 07/24/2010 10:13 PM
hey guys, just curious if any one knows wether the inner fenders are the same on a 50'one ton as a 1/2 ton?
tyler h #664933 07/25/2010 3:03 AM
1/2, 3/4, and 1 ton are the same.
Garandboy #665046 07/25/2010 5:25 PM
great,thanx. i was hoping to use all my sheetmetal from the 1 ton for my 1/2 ton chassis, but a i was curious about a few things, the inners, the front splash apron and running board mounts.
tyler h #665075 07/25/2010 7:31 PM
Running board mounts might be different?
Better double check those before assuming they are the same.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #665127 07/25/2010 11:57 PM
i looked at the 1 ton rb brackets and they look the same, but i dont have the 1/2 ton brackets at home to compare so i'll cross my fingers!how about the splash apron?
tyler h #665136 07/26/2010 12:31 AM
Splash apron should be the same.
Bumper is about 1/4" thick on a 1 ton, and much thinner on a 1/2 ton, if you were curious.
Looking in the parts manual will answer and confirm a number of your questions.
Start here:
http://chevy.oldcarmanualproject.com/
End up here:
http://chevy.oldcarmanualproject.com/1929_54chevyparts/index.htm
Grigg
---All pictures---
Grigg #665190 07/26/2010 5:19 AM
thanx grigg, i figured the bumper was different(thicker) those things are stuot! i'm mostly curious as to what WONT fit, i have cross ref'd some parts in the catalogues and alot of it is the same or at least useable.
Moderated by  Dusty53
