| | | Forums66 Topics128,074 Posts1,055,913 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 86 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 86 | hey guys, just curious if any one knows wether the inner fenders are the same on a 50'one ton as a 1/2 ton? | | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | 1/2, 3/4, and 1 ton are the same. | | | | | Joined: Oct 2009 Posts: 86 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 86 | great,thanx. i was hoping to use all my sheetmetal from the 1 ton for my 1/2 ton chassis, but a i was curious about a few things, the inners, the front splash apron and running board mounts. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Running board mounts might be different? Better double check those before assuming they are the same.
Grigg | | | | | Joined: Oct 2009 Posts: 86 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 86 | i looked at the 1 ton rb brackets and they look the same, but i dont have the 1/2 ton brackets at home to compare so i'll cross my fingers!how about the splash apron? | | | | | Joined: Oct 2009 Posts: 86 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 86 | thanx grigg, i figured the bumper was different(thicker) those things are stuot! i'm mostly curious as to what WONT fit, i have cross ref'd some parts in the catalogues and alot of it is the same or at least useable. | | |
