5 members (JW51, Gdads51, John L., DadsFirstPickup, 3B), 104 guests, and 1 robot.
Topics128,118
Posts1,056,305
Members48,439
Hi,
Can anyone tell me what manual transmissions will work with an open driveline and bolt up to the stock 216 bellhousing for a 1950 pickup?
Bob
1950 Chevrolet 1300
Hi Bob,
I don't know much, 'cept that I put a T5 behind mine. I also know I have a 4speed(granny first) from a '60 (opendriveline) that was behind a 235 taking up space in the shop. Also got a 3 speed from a '59 (thanks Photo!) sitting around. All will bolt up to you're 216 bellhousing.
If you want/are going to use that three speed or four, chances are you can get either off my hands real easy.
Good Luck.
Thanks Colin, have to finalize my plans for the truck but I may be interested in one of those. Think the 3 spd would work with a column shifter?
Bob
1950 Chevrolet 1300
An SM420 should work, as should the old "coffee grinder" fourspeed from the 30's and early to mid 40's -- so long as you've got one from a 3/4 ton or larger.
A 3 speed from a late fifties model (SM318?) should do the trick too.
Most any GM manual used behind a straight six or a V-8 from '55 on should be workable, some with more work than others.
If you want a 3-speed I'd look for one of the later ones that has syncros in all three gears.
Hey Bob,
You're reminding me I've still got that 1956 3 speed stuck to the back of my 261 that I don't need. I don't know if it has a syncro first though.
Curt
You Tube
I forgot you had that transmission. I'm not sure how to tell if it has a syncro first though. The newer 3 speed I have won't bolt onto the bellhousing I got from you.
1950 Chevrolet 1300
A '56 3 speed won't have a syncro first gear. That wasn't adopted until the mid '60 (66?). Most likely it's an SM318, which uses a slider gear for first and reverse. A way to tell if it's a '55-early'56 or late '56-up is by the shifter cover, the 55- early '56 use a seal that looks like a small axle seal, the late '56-up uses O-rings.
Bill Burmeister
learn to do a search on ??? subject.
if you keep it simple and use key words more info will 'pop'up
>>> transmission or sm (short for sm420 or 465 tranny) or T5, or T56
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=012148#000001
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=012135#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=012032#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=011748#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=011640#000011
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=5;t=000953;p=2#000059
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=011540#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=010333;p=1#000000
and there is TONS more info
Jim & Caroline
The three speed is set up for column and still has the linkages.
Good Luck.
To all you guys offering all those transmissions - I guess I'm in the wrong province!!
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
That's one good thing about Alberta, lots of old trucks to pick parts off of. Should be able to find SM420's just about anywhere though, they were used for a long time.
Decided to go with Colin's SM420, gives me the low first and sychro 2-4. Think it should work well with a rear ratio in the low 3's.
Bob
1950 Chevrolet 1300
