3 members (Otto Skorzeny, klhansen, Bwana-Jim), 75 guests, and 1 robot.
Topics128,036
Posts1,055,450
Members48,422
#664145 07/21/2010 9:07 PM
V
V Offline
I just bought an engine. It is either a GMC 235 or a Chevy 235. I need a flexplate that will fit. What year vehicles have this same flexplate? It would be useful if I could find a bolt pattern too.
GMC didn't offer a 235. What transmission do you plan to use? Chevy used a powerglide in cars that used a flex plate.
V
V Offline
i plan to use a turbo 350 transmission
Jessica's Truck
The true definition of insanity:
To do the same thing the same way repeatedly and expect a different result each time.
If you want to use a turbo 350 your going to need more than just a flex plate. Your also going to need an adapter because the bellhousing for a turbo 350 will not match the 235 block.
V
V Offline
I am aware of the adapter, and can get that, i'm just not sure about the flywheel
Jessica's Truck
