| | | Forums66 Topics128,035 Posts1,055,447 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | I just bought an engine. It is either a GMC 235 or a Chevy 235. I need a flexplate that will fit. What year vehicles have this same flexplate? It would be useful if I could find a bolt pattern too. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | GMC didn't offer a 235. What transmission do you plan to use? Chevy used a powerglide in cars that used a flex plate.
| | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | i plan to use a turbo 350 transmission Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | If you want to use a turbo 350 your going to need more than just a flex plate. Your also going to need an adapter because the bellhousing for a turbo 350 will not match the 235 block. | | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | I am aware of the adapter, and can get that, i'm just not sure about the flywheel Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | |
