2 members (HandyAndy, DaveV), 91 guests, and 3 robots.
Topics128,095
Posts1,056,067
Members48,433
#664213 07/22/2010 3:10 AM
Looks like I need a new starter, cranking real slow even with new battery. '54 235 engine in '52 3100. Truck converted to 12 volt.
Sources for starter?
Wayne
might make sure your cables are sound and the gound connection is clean and secure first, if it acts the same, then find an auto electric shop, they'll test and repair it .... otherwise, try the swap meet for a good used one
I'll second that. Check cables for internal corrosion and separation. Check all cable connections are clean and tight and all ground straps are present. I had a cable that sulfated (?) inside the insulation and went open. Took a little tracking down as it was an intermittent problem.
