12 members (Charles in CA, MickeyP, GIJOE298, joe apple, Jon G, Ribside, 3B, Bill Hanlon, lumbersawyer, 55shaker, dt235sd, 1 invisible),
97
Mod | | | Forums66 Topics128,134 Posts1,056,738 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 12 New Guy | | New Guy Joined: Aug 2009 Posts: 12 | I'm running a 65 model 292 the oil pan is to long/close to the ground. It was suggested that i check the dimentions of a 250 oil pan but havent found much info there..
I need to switch to a different oil pan or cut and shorten mine. If anybody has any instight on this I would be greatful | | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | I have a 250 pan laying around here, what would you me like to measure?
Joe | | | | | Joined: Aug 2009 Posts: 12 New Guy | | New Guy Joined: Aug 2009 Posts: 12 | Hey Joe,
From the bottom somewhere close to the plug UP to the gasket area
Thanks a ton | | | | | Joined: Aug 2009 Posts: 12 New Guy | | New Guy Joined: Aug 2009 Posts: 12 | the 292 has a 9 inch deep pan, I would like to be around 6 | | |
