5 members (Peggy M, dt235sd, Hotrod Lincoln, Oswald, Dragracefan), 117 guests, and 1 robot.
Topics128,131
Posts1,056,721
Members48,454
#664171 07/21/2010 11:25 PM
I'm running a 65 model 292 the oil pan is to long/close to the ground. It was suggested that i check the dimentions of a 250 oil pan but havent found much info there..
I need to switch to a different oil pan or cut and shorten mine. If anybody has any instight on this I would be greatful
Junkbike #664190 07/22/2010 12:46 AM
I have a 250 pan laying around here, what would you me like to measure?
Joe
Joe H #664192 07/22/2010 12:54 AM
Hey Joe,
From the bottom somewhere close to the plug UP to the gasket area
Thanks a ton
Junkbike #664194 07/22/2010 12:57 AM
the 292 has a 9 inch deep pan, I would like to be around 6
