3 members (Bill Hanlon, 32Fordpuchoptop, 1 invisible), 103 guests, and 2 robots.
Topics128,049
Posts1,055,635
#66402 09/25/2006 1:17 AM
Junior Member
Junior Member
does any body know of a lift kit for a 1951 chevy 3800 or a way to lift it without changing frames i just want a 6 inch or so lift thankyou for your time
derek
#66403 09/25/2006 2:23 AM
No aftermarket lift availible, you'll either have to make your own or find a Napco truck/parts. If you do it like the Napco was done, that's roughly 7" of lift just doing the conversion. You might also be able to adapt the suspension components from a later 4x4, like a mid'70s-mid '80s Chevy, to your existing chassis. Take a look at Stacey Davids Sgt. Rock project, you might be able to get some ideas for doing the conversin from that.
Bill Burmeister
#66404 09/25/2006 2:33 AM
Junior Member
Junior Member
what is Napco?
#66405 09/25/2006 2:41 AM
napco was an authorized converter of Chevy and GMC trucks to 4 wheel drive up to '57, then supplied parts for the factoy 4x4s to '59.
check out this http://www.napco4x4.org/ for more info.
Bill Burmeister
